Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
If I was working on a lighting circuit, and the IR test came out at 0.8M, would I not be able to carry out the work on the circuit until it had been rectified? Also if that result came out on a periodic what code would it be?
Any switches with neons, ELV transformers or dimmers still in the circuit?
Burglar alarm tapped off the lights?
Outside light with a damp problem?
Periodic, I'd code it as 3
You can't carry on working on that circuit, as the minimum required IR is 1.0MΩ for a 230V circuit, so you can't sign this circuit off as being compliant with BS7671 on your EIC / MEW
In that case, anything less than 2M ohms there is a possibility of a latent deferct and would require further investigation.
The book you need is Guidance Note 3
