I
imamartian
I need to fix two pergola posts to a wall. The posts are standard 75mm x 75mm, but need to be 12mm away from the wall - so i have got 12mm spacers. Question is, i am using (and i'll change to imperial here) 6.5" frame fixers, 3.5" of which is through the post and spacer, so will the remaining 3" be sufficient to anchor to the wall?
I'm using 3 frame fixers per 8ft post, although the top of the pergola will be bracketed to the wall to add to overall strength.
Ta.
Ta.
