Why do people wire washing machines to spur units? Last time I came across this I just replaced the spur unit with a 13A socket.
Two reasons:
1. Fuse discrimination. It is a basic principle of electrical design not to have two fuses of the same value in the same circuit chain. The largest fuse is always nearer the supply and sized so that the smaller one will blow before the larger.
2. Access to the plug. An appliance full of water is hard to move if the fuse in the plug blows and it is behind the appliance.
Also a flex connection plate is not as deep as a plug and socket. This is needed in many situations so that the machine does not stand out from the
base unit. I will ALWAYS use one for an integrated built in appliance.
1. There is only 1 13A fuse after the consumer unit in either case, either in the plug or in the fused spur unit.
2. But the fused spur unit is often behind the appliance as well! Anyway if the fuse has blown there is a fault and most likely the replacement will blow as well, so an appliance full of water remains.
3. I concede on the thickness issue, but even so a plug and socket well placed (perhaps in an adjacent cupboard) is no issue.
Normally there is an FCU at high level which contains the fuse. Then at low level there will be a flex outlet plate to connect to. Ive never actually seen (in an installation thats been done properly) a fused connection unit with fuse at low level behind the appliance.
Cutting the plug off does not invalidate the warranty. Infact in every single manual for my appliances it states that you can do it, and even shows you how with a diagram.
