Have recently bought my first house - an ex-council house. And it has microbores (8mm) feeding all the radiators in the house. Which is ok for most as they come off a 15mm pipe fairly close (1-2m away) to the rads themselves. But my main bedroom and lounge are fed off one microbore pipe.
The drawing below might show better detail but the feed pipe comes from the boiler in 22mm, splits into two 15mm pipes. The one i'm concerned about splits again into two 8mm microbore pipes. One way goes 1-2m into a small bedroom (2.75m x 2.4m) rad and the other way travels 3.6m where it splits off into a large bedroom (3.5m x 3.5m) rad while the rest carries straight on to the corner of the room down the lounge wall (2.35m high) and along into a rad big enough to heat the lounge – 6.5m x 3.5m.
Total distance travelled since leaving the 15mm = 8.35m in which it needs to heat the bedroom and the lounge. total btu needed is around 15000 btu
Do I need to change it to 15mm in order for both rooms to be heated sufficiently? I have cavity wall and plenty of loft insulation too.
Some have said that the long microbore pipes will not heat the rooms comfortably while my dad who is helping with DIY seems adamant that it's fine.
I shall be swapping the rads around as they currently stand in the drawing. lounge will have 600x1600 double and bedroom the 600x1800 single.
Anyone have any ideas?
http://img.photobucket.com/albums/v514/Anoobis/9_0069.png
