Is Ply a viable option?
16 Nov 2016
Probably this is a common question but i couldn't easily find the answer.
Shower being built in corner of two stud walls.
Studding doesn't line up with chosen shower size for a secure fixing for the glass support track.
I "was" going to put green plasterboard for the walls and tile over. However i am not happy about the shower screen and doors being supported only in the plasterboard.
So options might be:
take out insulation (loft conversion shower room) and add more studs and noggins where screen "might" go (may change shower size at some point)
or
Sheet with 12mm marine ply instead
I am assuming that other types of backing boards (marmox, hardi etc) will also not be structural for fixings ( I also have not planned to use )
So as i have other small bathroom back to wall units to add in this room, would the ply be a better (more expensive) option or will it cause me issues with tiling and movement?
Ply is a poor choice for tiling over. Plasterboard is not desirable for a shower area either, regardless of it being the green type or not. It all disintegrates when wet, the 'moisture resistant' type just takes a bit longer to fall apart.
If additional strength for fixings is required, fix 18mm ply between the studs where items will be fixed, so the ply is flush with the front of the studs.
Do the walls in the shower area with cement board, others can be plasterboard.
Any fixings can then go through the tiles and cement board and into the ply behind.
