- Joined
- 11 Jun 2012
- Messages
- 91
- Reaction score
- 1
- Country
Hi, I bought myself 2 solar powered lights for the side of the house, both pretty bright and seem decent, tested both prior to putting on the wall and both worked fine.
Link to the ones i bought below:
Link
The one that's in the back part of the garden comes on very bright when it gets triggered, which is good. This one doesn't get triggered very much, so assume the battery is pretty high most of the time in it.
The brightness of the one at the front of part of the side of the house is a lot less since putting them up.
I have also found (which I didn't read when I bought them) that the range is 5m, although when walking on the footpath 2 houses away keeps triggering it. It says 5m range, but it must accept a little more than that, I would say it's more about 7-8m when I get to their house.
The lights were stuck up using bonding tape, so I don't really want to take it off, and it look all a bit rubbish. The battery in the light is obviously being triggered all night every time people walk up the road. And this is obviously draining the battery.
The main purpose was only to offer a bit of extra light when we go out of a night to do bins etc
There is no switch to change the sensor range, so I wondered before I pull it off the wall. Do I have any other options to lower the range on it, or even block a certain direction from triggering it?
Unfortunately, the sensor seems pretty good, but is also on the small side.
Regards
James
Link
Regards
James
