    Dismiss Notice
Is this a bathroom disaster?
Discussion in 'DIY Disasters' started by PhillipD, 16 Jan 2016.
  1. PhillipD
    PhillipD
    15 May 2015
    3
    Thanks Received:
    Nottingham
    Country:
    This isn't my own DIY disaster but just wondering if a bathroom builder has left us a disaster. I tripped up over our bath panel and decided to have a look under the bath before putting it back and I'm not sure I liked what I saw! It appears the plaster on the outside wall was removed from below the bath line , so the wall behind front of the bath with the taps has no plaster - you can just see brickwork and the bath rests on just two metal supports directly on the floorboards.
    We had this done over five years ago but just wondering if we ought to have it looked into?
    Phillip
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    It is not unusual to have the plaster stripped back to brick below the bath, it will have no adverse effects.
    With regards to the two metal supports, do mean that there are two metal frames that have legs/stands on to support the bath, if so this normal, I would expect a central leg, but not all baths are designed to require one.
  4. Chri5
    Chri5
    19 Jan 2007
    4,289
    Thanks Received:
    391
    London
    Country:
    The absence of plaster at the bath line help that wall side of the bath inset to the wall which isn't a bad thing , tiles then easy the amount of sealant and the potential for water to run behind the bath.
    If the house was old enough to have a cast iron unit then due to weight they were often put in position at house build 1st fix due to weight, size etc. If that was the case then the wall could never have have plaster, since at build the bath was in the way of the plasterers.
  5. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    Oh... I though this was a thread about another of my mother-in-law's bathroom disasters. Luckily we had the foresight to cover the carpets in her room with Roll 'n Stroll when she moved in for six months while she receives chemo.
  6. Aquaheat
    Aquaheat
    19 Nov 2007
    3,088
    Thanks Received:
    591
    Lincolnshire
    Country:
    WTF? You sound like such a caring and considerate person.
    • Like Like x 1
  7. RigidRaider
    RigidRaider
    9 Aug 2006
    1,727
    Thanks Received:
    68
    Lancashire
    Country:
    We are actually, very. However when somebody stands while changing her incontinence pads, drops poo on the bathroom floor, treads in it then shuffles across the landing and around her room smearing it all over the carpets you will understand that hiring a carpet shampoo machine every couple of days becomes expensive and roll 'n stroll is a practical solution because you can mop it.
  8. DaveHerns
    DaveHerns
    11 Nov 2009
    2,582
    Thanks Received:
    207
    Country:
    It's not easy looking after the elderly. I sympathise with you
  9. Sponsored Links
Loading...
Share This Page
