Hi
I moved into my home (freehold and mortgaged so no freeholders or landlords applicable) 3 weeks ago. This morning the downstairs toilet made some bubbling noises although no plumbing appliances were being used in the house. Anyway I plunged the toilet a few times after flushing it as at first it seemed to take a bit of time to take the water away. Anyway it started flushing/clearing fine and no more bubbling. This prompted me to look in my back garden and open the manhole cover! In there I could see that there was murky water which was not drained away. After some experimentation today (what a way to spend a day) I noted that the levels filled after say a bath and then slowly reduced although did not clear to below the big pipe I could see in there. There are no problems in the house with draining water away or anything like that and the water is not rising to any levels that threaten to flood or overspill. However I suddenly remembered that a damp contractor called in when we had the survey noted some minor levels of damp on the ground gloor area which is near this pipe which seems more than coincidence.... Anyway I suppose I am asking:
1. Is it normal for some water to sit in the drains like this and/or does it take a while to drain away?
2. If not I am assuming that there is a blockage somewhere past the drain to my house as it drains okay from my appliances yet not past the external drain. I am end terrace so does this become the public sewer?
3. Do I ring Thames Water (the local water authority), Dyno-Rod or a plumber?
4. Could this problem have been there for months or even years and therefore although needs fixing is not an emergency?
Thank you!
Thank you!
