Is this article a Red Haddock ???
Years ago an elderly friend had heating problems, the lounge, where thermostat was, was always cooler than wanted but the rest of the house was very hot, the heating ran for long periods. I tried turning the lock shied valves down and yes it made a difference in as much as other rooms were a little cooler but turning them down further meant the boiler over temp stat opened and took ages to reset.
However the real problem was the lounge radiator was obstructed by the sofa and the room was so small there wasn't many options available to resite either. I added some papst fans from 19" rack units to blow air into the limited space betwixt sofa and rad which made a difference.
Ultimately I cut a hole through the lathe and plaster wall and set the 4 fans in the wall between the bedroom and lounge rad's which backed onto each other such that bedroom rad hot air was being blown in behind the lounge rad. I wired it to the room stat with an additional stat behind the bedroom rad to make the fan run on until cooled but with a switch which they turned the fan off a while before going to bed to raise the bedroom temp. A lot of rebalancing later it worked very well and yes it did save money as the boiler cycled more often, preventing the other rooms overheating.
Yes that makes sense too, nice explanation
Our living room radiator, is in a bay window, and if blocked in by the usual style of sofa, would suffer the same issue. To get around it, I deliberately chose a sofa, on small legs, so there was space under to allow air flow, through to the rear and the rad.
Yes same here with one radiator, hence why I was looking at the fans, but wife is looking at getting rid of sofa, in the room, three easy chairs, sofa 3 persons, and 6 chairs for dinning table, were moved in when dinning room was used as a bedroom, and never moved back. Not really a small room, L shaped, and shortest wall 5 x Ikea Billy bookcases against it.
But the Myson in old house did not seem noisy in the day, but at night would need to turn up the TV a bit when it fired up.
And I am not sure if the oil on/off boiler is causing the hysteresis or the way the electronic TRV heads work? Today I feel cold, thermometer on table next to PC shows 19.6°C the TRV behind me 19°C, behind sofa 19.7°C and the wall thermostat 20.5°C and set to 20.5°C and heating not running, radiator cold. Did not take readings yesterday, but felt warm, the Kasa TRV will show a graph, as will the wall thermostat 1769005704894.png1769005594935.png and it seems as if heating is doing as it is told, so why do I feel cold? Maybe because it is a dull day? Phone tells me 8°C which is also what the wall thermostat shows, where it gets it from I don't know, must be the internet in both cases.
If the room was 20°C in the summer, I would be thinking it was hot, so maybe kid ology works?
I think you might be right Eric.
I do notice that throughout the year as ambient temperature varies the a lot of folk tend to like the home noticably hotter when its cold outside then when its warm or hot outside as soon as they get indoors wheras you might presume one steady temperature inside whether hotter or cooler outside and just wait a while to heat up or cool down accordingly.
I once noticed when working in a dental surgery the staff leaving for lunch and whacking the room stat right down then on return from lunch whacking it right up full. Why not just an ON/OFF switch! or better still leave the stat at one setting everyday during working hours? LOL
I was asked to fit "Tamperproof stats" in a few working Mens Clubs etc to prevent a few individuals whacking it up or down everytime they walked past it!
