I have a 10 way consumer unit
When I turn the breaker for "downstairs lights" to the off position the lights go off downstairs.
When I fitted a light in the dining room and one in the front room both times it tripped the main breaker with the "downstairs lights" breaker in the off position?
This only happened when I connected the last wire to the light both times.
Is this correct?
All lights are working fine and nothing blew as far as I know.
Should i have turned the main breaker off as well when doing it? (I didnt want to work in the dark) I had three cables on one light fitting and two on the other so I figured it was a loop. I wired switch wire to the live on the light, earth to earth, neut to neut and the remaining brown wires were onto the loop part of the terminal so I hope that was ok.
Is this correct?
