Isolated bell box! Cant remember!
6 Nov 2008
hi
We had some work done on our house over a year ago that involved disconnecting the texecom Veritas r8 system
I vaguely remember climbing up to the bell box and fitting a black jumper thing on some pins to turn it off. Would this be right?
I would like to reinstate the alarm.
Sounder is a Citadel Defender.
Probably not ....as most will work without the battery link on ....probably the lid screw is not in fully
Will check the tamper when i get up to put the link back on.
Another question, when i enter the access code at the panel all of the zone lights come on.
Is that right?
Ok
Managed to sort the bell box and now have a healthy keypad with no faults and green light on.
The pir’s have all been changed but i noticed they do not illuminate when in front of them?
Any ideas?
Post picture of pcb ....the new ones don't have fuses....you may need a multimeter to do any further checks
Def no fuses on the pcb.
Pir sensors are not lighting when in view
When i enter access code at control panel, all zones light up red. will not allow me to set system
Factory reset??
No....if it's a newer unit with the self resetting fuses , remove all power from aux and put one set of power connections back in one at a time , sounds like a short on a device
Aux in the panel?
Also im going to try to de-power the panel & remove the battery to reboot. Will this trigger the bell box?
