Nope.
No, it wasn't vision based, it was primarily radar based at that time with Vision as a secondary input.Nope to what ?
The sensors on the car did not see the truck and thus the car's automatic systems thought the road in front was clear, hence the system did not call for a reduction of speed.
The radar system would ( should ) have received a reflection from the truck that indicated that there was an object in front of the car within the safe stopping distance for the speed of the car.No, it wasn't vision based, it was primarily radar based at that time with Vision as a secondary input.
No, that's not how they work. I can find you something to read on it but the short version is they need at least two reflections to identify the closing speed.The radar system would ( should ) have received a reflection from the truck that indicated that there was an object in front of the car within the safe stopping distance for the speed of the car.
No ACC can pick up that sort of closing speed. It was a critical factor.Closing speed is not the critical factor in this incident, critical was an object in the path of the car that was it seems not detected by the sensors,
If the radar had Doppler speed detection then a single pulse would have detected a stationary object (*) in front of the car and known how far that object was from the car.
The car's own speed sensors would ( should ) have provided a value for the minimum safe braking distance.
(*) the truck was crossing the highway hence the vector along the highway would have been zero
I wrote "could claim". Light and radio are both e.m. radiation. You may think they're different, until you see Maxwell's equations, and try (and fail) to find a discriminant.Light may be a category of radiation, but few would accept that a laser is a radio device.
The Wired article is a good introduction.
How the hell did Volvo leave out a sensor for the bleedin obvious?No ACC can pick up that sort of closing speed. It was a critical factor.
...Light and radio are both e.m. radiation. You may think they're different....
