joinng cooker cables - choc box connectors?
1 Sep 2010
Essex
simiar to my last post, can i use choc box connectors to join cooker cable where i have removed a switch. a friend had this done by a builder (we took the panel off to have a look today as i want to do it) they looked fairly chunky ones and were wrapped up in insulating tape. would this be ok or a bad move?
any help appreciated.
Wago do connectors that go up to 6mm and 41A. Maintainance Free and much better than connectors when put in one of their boxes
Edit: Linky:
http://secure.wago.ltd.uk/shop/product/773-173_supplied_in_bags_of_25/
Don't tape connector blocks up with insulation tape, connector blocks need to be in a proper enclosure.
You can get large junction boxes for cooker cables, however any screwed join in a cable still needs to be accessible.
Hope you don't mind if I jump in here but the term "accessible". . . . this can mean many things: From plastered into the wall so totally unaccessible through to fully accessible because it is surface mounted and visible.
With under a floor board, that can be lifted if access is required, somewhere in between the above two examples.
Just wondering if a cable joint under a floor board in a suitable 30A junction box would be considered "accessable"
Thank you for your time.
NO!!!...
plastered into a wall is by no means accessible in anyones definition..
under a floor would only be accessible if you can get at it without the use of a tool, so something like a hole plugged with a SBC cover ( SBC is a big hole saw that drills a recessed round hole and you buy plastic covers that fit in the hole ), or a specifically installed lift off hatch..
this then becomes inaccessible the second you put laminate flooring or tiles down though..
Hope you don't mind if I jump in here but the term "accessible". . . . this can mean many things: From plastered into the wall~~~~~~~
With comments like that I think most sensible people would prefere that you did not jump ever again.
I don't have a photo of the hole in the wall where a terminal block extending a cooker supply and plastered into the wall overheated, melted, shorted, "exploded" and blew plaster across the room.
I suppose you would say that was "easily accessible" when repair was needed
