I'm fitting one of these lamps to the upstairs landing...
http://www.thelightingsuperstore.co.uk/product.asp?productid=26541
I currently have a ceiling rose which I am going to replace with a junction box, positioned in the attic. The current circuit is using 1.0mm cable.
My set up will resemble this:
I was going to use the same 1.0mm cable to connect the light fitting to the juntion box, but the diagram above suggests I should be using Heat Resistant Cable.
The light fitting comes supplied with three sleeves that look like this:
http://cableorganizer.com/images/techflex/nomex-lg.jpg
My question is, do I need to use heat resistant cable to connect the light fitting to the circuit or can I use the same 1.0mm cable and just wrap the seperate wires (SL, N, E) in the sleeving inside the light fitting.
The only part of the cable that will be exposed to heat is the bit inside the fitting, and if these 3 wires are sleeved then isn't that safe enough? When you strip the grey sleeving from heat resistant cable, is it still heat resistant?
In the event that I do need to use heat resistant cable, which size should I be using for this installation?
http://www.tlc-direct.co.uk/Main_Index/Cable_Index/Flex_Heat_Resistant/
Many Thanks
d.
Many Thanks
d.
