key pad not got power to it power
19 Aug 2009
Lincolnshire
i have decorated my hall and took the key pad off the wall, only to find when i put it back on it does not work or light up checked the 2 fuses in control box they seem ok all the sensors work the main bell box on stand by the key pad has 4 wires going to it
Most keypads have a 12 v pos and 12v neg plus a data send and data return wire. Check the connections of the 12v pos and neg. Check there is a voltage with a meter.
Double check you have the cores back where they should be.
As you have already opened the panel, you can do so easily again and check which colours are used. Make sure they are the same at the panel and keypad.
now got power back to the key pad but the keys bleep when i push them they will not set the system up try to put the code in and then the engineers code 5678 still nothing
