Keybox that's actually secure?
Can't remember the one I got but it was so the carers could let themselves in when I was bed-bound.
It was a sold secure or secured by design model recommended by police and came with 100mm masonry screws (the type that screw direct into a hole without a plug) that were 10mm diameter.
Solid construction.
Many years ago, despite them trying to rip my back door to sheds, some scumbags just went around the front and kicked the front door in.
A very common method.
IF you have glass panes in the window the nearest brick or garden tool will be used to remove them so access can be obtained.
These keyboxes are a semi secure method of making a key available to others that know the code.
They are ALL simple enough to break into if you know how, instructions are on Youtube.
Your probably more secure hiding a key under a flower pot that unlocks another lock that unlocks another lock (all in different locations) that gives final access to the key.
Security only keeps out the honest person, the dishonest person WILL gain access when they want.
What about insurance cover - have a look as it may only cover for forced entry so if they whack the pathetic wall key box and get the key you kindly left there for them and let themselves in then it is not forced entry and you may not be covered.
