    Dismiss Notice
Kitchen - Cutting Kickboards Around Skirting Boards
Discussion in 'Wood / Woodwork / Carpentry' started by 356Speedster, 7 Apr 2010.
  1. 356Speedster
    356Speedster
    14 Feb 2007
    25
    Thanks Received:
    Worcestershire
    Country:
    Hi all.... can anyone help me pls? I'm coming to the end of my kitchen project and just have 3 kickboards left to fit. Unfortunately, to make them a tight / neat fit, they all need to have their ends moulded into the skirting boards.
    The skirtings are builder std items, which are mostly flat, with a couple of curves at the top, approx 13cm high.
    I could cut the skirtings off, I suppose, but it's going to be very tight getting under the fitted units to do so. As such, i'd prefer to profile the ends of the skirting to suit, if that's not too difficult.
    Any ideas?
    Thanks,
    Mark
  2. Sponsored Links
  3. speed
    speed
    15 Nov 2009
    81
    Thanks Received:
    13
    Sheffield
    Country:
    depending on your tooling,
    cut the skirting off with a multimaster
    if you dont have one you will have to scribe the plynth, with a jigsaw and downcutting blade
    if you dont have a jigsaw a good old coping saw
  4. noseall
    noseall
    2 Feb 2006
    39,961
    Thanks Received:
    2,515
    Staffordshire
    Country:
    As stated cut the skits up to the plinths.
  5. 356Speedster
    356Speedster
    14 Feb 2007
    25
    Thanks Received:
    Worcestershire
    Country:
    Unfortunately I don't have a Fein Multimaster, and would prefer not to cut the skirts off to be fair... kickboards are easier to replace should the need arise!
    Following research, I've been considering getting a Profile Gauge, Coping Saw & file, to closely match the kickboards to the skirts.... a bit manual bit it looks like it would do the job... maybe??
  6. big-all
    big-all
    12 Jul 2004
    18,521
    Thanks Received:
    1,430
    Surrey
    Country:
    tip
    cut the plinth several inches longer than you need to allow several mistakes
    get an offcut or short bit off skirting you can temporarily remove
    check for lean on skirting you are scribing to visualy or with a sliding bevel :D
    use a workmate workbench or kitchen table protected by a table cloth sheet or blanket coverd in ply/mdf clamped on
    hold the skirting at the correct angle against the plinth and mark with a sharp pencil
    if you have only one or two probably quicker to scribe in situ unless very awkward
  7. 356Speedster
    356Speedster
    14 Feb 2007
    25
    Thanks Received:
    Worcestershire
    Country:
    Thanks for the tip Big All..... nothing in this house is stright and checking for lean is v.important!!
    Good tips, I've got a few spare bits of board, so will do as you say :)
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
