- Joined
- 22 Nov 2017
- Messages
- 55
- Reaction score
- 0
- Country
I'm slightly going mad trying to operate the vertical adjustment for my DIY Kitchens wall cabinets. They look to be fairly standard, so wondering if I'm just totally overlooking something obvious.
I think the hardware on the back of the cabinet is a "Traser Rapid 6" - if not, then it is very similar in appearance. Video of how it supposedly works here:
As you can see, once hung on the wall, you can access the hardware from inside the cabinet to adjust the tightness of the cabinet against the wall; and adjust the height of the cabinet on the wall. Tightness to the wall is via a normal cross-head screw. This I can do fine. Height however is adjusted by inserting a screwdriver into a hole which leads to non-standard screw, positioned at 90 degrees with little teeth on top. I presume the idea is that the screwdriver edges catch the teeth and result in the screw turning.
I found the pdf spec of the Traser Rapid 6:
https://www.indaux.com/en/products/doc/29/1/traser6ing.pdf
It suggests on page 220 that:
"Height adjustment Up to 18mm with a Phillips® No.2, Ø6 screwdriver or a Pozidriv® No.2, Ø6."
All of the screwdrivers I have either don't fit in the hole, or if they do fit I can't get them to actually turn the screw. I bought this set of screwdrivers thinking that it included a screwdriver with the above spec (1 x PH 1x80mm, 1 x PH 2x100mm, 1 x PZ 1x80mm, 1 x PZ 2x100mm, 1 x 0.8x4.0x100mm, 1 x 1.0x5.5x125mm) https://www.amazon.co.uk/gp/product/B000297UEI/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
None of those work either.
Can anyone advise either what I might be doing wrong; or point me to a Screwfix or B&Q screwdriver that matches the above. I'm not sure what "Ø6" means and I've not had much luck searching for it.
Grateful for any help!
