Does anyone have any suggestions what to do where the worktop reaches the window ledge?
As you can see in the picture below (without the worktop) the units are just below the level of the window so once the worktop is added there will be a big gap between the top of the worktop and the bottom of the window frame.
The worktop is one of the laminated ones and won't stretch all the way into the window bay. Should I try and build up the window area so it finishes level with the worktop if I tile it - or raise it up a bit, so the tiles sit higher than the worktop?
Also as that's where the sink will be should I seal the back of the worktop with anything?
Thanks in advance.
Thanks in advance.
