I have completed all of the installation of our new kitchen and it has gone really well. However, I have to make a 90 deg worktop joint using a jig.
I have all the necessary equipment ( jig, clamps router etc ).
The one problem that I have is the router. It has only capacity for 8mm dia shank router bit and I have been told to use a 50mm length cutter. The longest that I can find at 8mm is 25mm. Can I get away with using this as the plunge depth on the router is 50mm? It seems a bit extreme to have buy a new router. This is the only part of the job that I have no experience of, although I have used the router quite a bit for other projects, and would welcome any help.
Thanks in advance.
Thanks in advance.
