3 days ago I laid Glued Tongue and Groove real-wood flooring in the bathroom and have now had to rip the lot up again
The boards when glued did not meet together properly, therefore there where gaps and no matter how hard I whacked it with a ‘block and mallet’ they would not meet, allowing dirt to go into the gaps. Regardless I continued as I thought this was normal for real wood flooring
After completing the floor, I went on to install a new towel rail which leaked. I repaired the leak, mopped up feeling delighted with the job
The next morning I woke to find the area around the leak had ‘tented’
I attempted to walk over it to resolve, lightly tapped with wood block/mallet to no avail, so I decided (as the gaps were bothering me anyway) to rip it up, right-off my loses and start again
So today, I am about to start again, but what went wrong
This is what I did …
The original floor was old ‘floor boards’. I nailed down, hoovered, laid and screwed down new Wickes 6mm MDF rigid boarding, hoovering again afterwards
Laid down ‘Floormaker’ laminate foam underlay (from a roll)
Place first row of boards leaving 10-12 mm expansion gap
Glued using Wickes interior/exterior weatherproof wood adhesive
Tap boards in with Block/Mallet and using the floor ‘puller’
Placed 10 mm Cork strip around edges (for expansion gap)
Somebody down the local mentioned they used a SPECIAL ADHESIVE but I cannot find a ‘special adhesive’ in either Wickes, B&Q or Homebase. Is this Wickes interior/exterior weatherproof wood adhesive not good enough
Would this ‘tent’ affect from the leak have disappeared if left alone
How do you get around the gap between the boards (I just ran single strip of glue along the tongue only)
Any advice would be grateful before I start again
