Laminate not sitting flat at front door
4 Nov 2013
There are two things I want to try and sort out here. I have attached an image showing the area in question.
The piece of flooring which runs up to the concrete step lifts slightly when stepped on, and I haven't quite worked out what to do about the concrete step.
I was thinking of glueing a piece of flooring to the Concrete and then using a door threshold to bridge the gap between them?
Hoping it would also stop the movement in the board as I clearly can't run beading across it to hold it down..
Ideas and thoughts welcome ☺
I'd do that same mate. Glue the board on step down and cut it neat.
Use a incizo bar between them, Greta wood trim for doing that.
