Until today I had decided that my new bathroom was going to have four downlights controlled by a pull cord switch inside the room, one illuminated mirror feeding from the lights, and one extractor fan wired to the light circuit via an isolator switch situated outside the room.
However, today I changed my mind, and I'd like to know if my new idea is workable or just plain stupid.
Ditch downlights and go with a central light fitting, this one to be precise:
http://www.thelightingsuperstore.co.uk/product.asp?productid=35785
At 40w and a warm white bulb I think this should provide more than enough light to bathroom of dimensions 1.7 x 1.9 x 2.6m (w x l x h). The four energy saving downlights I had in mind from TLC at 9w a piece would have provided 36w so I'm up 4w already.
My only concern is will I have a dark spot below the light? Will the circular fluorescent tube prevent this?
Now the problem with these lights are the warm up time. If someone just goes in for a few seconds it'll be fairly dim. So I was thinking of installing a second light, an LED spotlight, above the toilet.
Both lights would be controlled separately from a double switch situated outside the bathroom. So if you were expecting to be in there a while, you'd put on the central light, if only a short time, the LED light.
Is an LED directly over the toilet too much? Will it feel like I'm being beamed up by aliens?
Would a wall light be better?
Now if I move the light switches outside the room, I'll be using the channel and box I had originally planned for the fan isolation switch (I put it at switch height and not above the door btw). I guess I could cut another channel and put the isolator switch above the door like but I've already painted the ceiling out there and I don't really want to risk damaging it. So would it be ok to fit a pull cord isolator switch inside the bathroom, away from the bath and sink?
http://www.tlc-direct.co.uk/Products/ASCS3PIF.html
The illuminated mirror stays as is
What do you think? Do-able?
