I have a Ferroli Optimax 25c combi boiler which is losing pressure.
I have looked for a leak without success on the rads and pipework that I can see but most pipes are under concrete. There is no sign of dampness anywhere.
It is not losing pressure from the PRV but I have recently found a small leak from the boiler which seems to have now stopped after I tightened a connection. Someone said it may be a leaking heat exchanger.
Could this be the case and if so how can i confirm this before I end up having to dig up floors looking for a leaking pipe?
I am also regularly bleeding the heated towel rail (and topping up afterwards) - do't know if this is relevent
Any help gratefully received
