Folks,
I've got a shower thats leaking at the waste pipe (and caused all kinds of damage!). I'm no expert at all and as far as I can see the problem is that the rim around the plug hole is not tightly connected to the waste pipe (if you go under the shower and lift the waste pipe you can get the rim around the plug to rise a couple of mm). Presumably this is where the water is getting through? I tried turning the plug hole fittings to tighten it (it looks like it's attached to the waste pipe by some kind of screw fitting) and this seemed to help but not enough and I can't (manually) tighten it any more and wouldn't know what tools to use. Sorry for the long query but I'm pretty desperate for advice. Help!
