Leaky Swivel Tap in Kitchen
11 Jan 2012
Kent
Hi guys,
Have posted some photos of my tap that is leaking.
http://www.diynot.com/network/jonesp1/albums/
It is leaking from the swivel part and is quite common so i read.
Is this easy to fix or shall I just buy a new tap.
It doesn't always leak as in i can stop by putting the tap on and off again in a different swivel position.
The make is Reginox.
Any help would be appreciated.
Paul
4 Mar 2013
I presume the tap is leaking from the area shown with the black rectangle in your picture?
Looks like it needs a new cartridge.
If so it is not worth repairing. Reginox are cheapo taps so I would just replace it if I were you.
You could try looking at lunns.net for a new cartridge if replacement is not an option
11 Jan 2012
Kent
Thanks will prob buy a replacement.
Fitting a new tap. Is this fairly straight forward to do yourself?
Paul
26 Jun 2004
London
Does it leak all the time or only for a while after it has been used?
There will be seals on the swivel part which in theory could be replaced although on a cheap tap is hardly worth it except as a save money DIY project.
If it leaks all the time then it will be the cartridge leaking and on most cheap taps they are not easy to identify or obtain. Replacement is the easy solution.
I hate replacing kitchen taps as customers don't often seem to realise that all the rubbish under the sink has to be removed BEFORE my visit. Then its working lying on your back looking upwards. Not impossible but not vey pleasant either!
People at their computer keyboards don't realise that undersink areas are often wet and messy with rat droppings and fungus!
Tony
11 Jan 2012
Kent
It doesn't leak all the time and only after being used for a while.
It seems like you can get it in the right position and it won't leak or if you turn the tap off and back on again it seems to seal better and stop leaking.
It might be like you say just a seal.
I fancy giving this a go first if you could give me some direction please?
As for changing the tap I think I'll leave that for the experts.
Cheers
Paul
