Can any electrician recommend a supplier of LED batten lights that are easy to use to replace some existing fluorescent batten lights.
I’ve seen a few different makes of LED battens and they all seem to be sealed units with cable entry at one, or two fixed points. I need fittings with a choice of places on the back for cable entry. One of the fluorescent fittings I want to replace has power in at the centre, the cable to the switch leaves the fitting about 300mm from one end and the cable to the next fitting leaves about 300mm from the other end. Very easy for whoever fitted them but impossible with a LED that is a sealed unit with only one cable position.
I feel sure someone must sell LED fittings that give some flexibility when wiring them. I’m needed some 5ft and some 6ft fittings (1500mm and 1800mm)
