    Dismiss Notice
Replacing fluorescent battens - best option/s?
Discussion in 'Electrics UK' started by windswept321, 2 Nov 2019.
  1. windswept321
    windswept321
    7 Dec 2018
    3
    Thanks Received:
    Country:
    I have a couple of windowed small office type rooms - maybe 10 ft x 12ft for the biggest one, lit with 2 double 6ft fluorescent battens. The smaller room has a single 6ft batten fitting. Price, looks, utility and effort are the main factors here. Looks are a little more important for the smaller room.
    Options:
    I have single sided led tubes I picked up cheaply I could use, although this will mean rewiring the old, somewhat ugly fittings.
    I could fit pendants in situ with led bulbs which would be the cheapest option, although I’d need light shades.
    toolstation has cheap led battens at around £12 each.
    screwfix has led bulkheads at around £6 each.
    I’ve come across led panels but they seem quite expensive.
    Which of these, if any, would make most sense?
  2. Sponsored Links
  3. winston1
    winston1
    11 Jan 2010
    6,974
    Thanks Received:
    531
    London
    Country:
    6 foot florescent battens give an awful lot of light. I doubt that any of your options would equal it apart from a couple of LED panels.
  4. foxhole
    foxhole
    14 Mar 2006
    17,811
    Thanks Received:
    2,043
    Kent
    Country:
  5. Sureitsoff?
    Sureitsoff?
    27 Jul 2007
    772
    Thanks Received:
    126
    Norfolk
    Country:
  6. RF Lighting
    RF Lighting
    31 Mar 2006
    19,990
    Thanks Received:
    1,354
    Leeds
    Country:
  7. Sureitsoff?
    Sureitsoff?
    27 Jul 2007
    772
    Thanks Received:
    126
    Norfolk
    Country:
    i replaced one of the tubes in a twin fitting leaving the other space blank with the v tac tubes from toolstation and one led tube seems to be as bright as two flouescent tubes
  8. winston1
    winston1
    11 Jan 2010
    6,974
    Thanks Received:
    531
    London
    Country:
    The output in lumens of a LED tube is just over half of that of the same size fluorescent, easy to confirm as the output is on the packaging these days. Old fluorescents go dim and get dirty so appear dimmer than new LEDs. Of course LEDs will dim with age and get dirty too.
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
