I have two light fittings with LED bulbs, one ("the end one") is just directly connected to the other at the fitting, and then these are looped in at a switch - and there is a second two-way switch to operate them.
The end one flickers when off - but only if the lights were switched on at the two-way switch and switched off at the main switch.
I understand that this it's due to slight residual current in the circuit charging the bulb capacitor, but I wondered why this only occurs when the one switch is operated and why just the end fitting?
But the main questions are - is it a safety issue, and is it a fault - a faulty switch or circuit?
The two-way switch had a neon indicator. This can apparently be configured to come on with different switch operation. At the moment the neon is illuminated only when the lights are switched on at the two-way switch and off at the main switch - ie on when the lights flicker. I don't know if that's a clue or a symptom.
