I've just moved into a new build property which has a mix of existing LED downlighters and pendent fittings. I want to remove the pendents in the lounge, hallway & landing and replace with LED downlighters. I'm confident with the actual cabling work as i'm a security systems installer by trade. I plan to use the pendent feed to loop in & out of each downlight position.
Plan is:
Lounge - 4 or 6 lighters
Hallway - 2 lighters
Landing - 2 or 3 lighters
My questions are firstly whats the best way to measure out the position of each downlighter or is it simply a chalk line? Obviously a mesure up in loft too to avoid joists.
Whats the best type of light, mains driven units or seperate transformers and is any dimmer switch compatible? Any recommendations welcome.
Thank you.
Plan is:
Thank you.
