Left hand switch on single gang 13 switched wall sockets?
15 Nov 2006
Devon
Are there any left hand switches on single gang 13amp switched wall sockets?
I guess I could just turn the socket upside down but it will not look right will it?
Any help appreciated
Many thanks
Why do you need to know?
I am disabled and find it really hard to operate the switch in its current position.
I thought that it would be much easier if a left handed switch was available as the alternative is to move the existing socket by some 300mm.
The switch on the socket needs to be to the left of the plug when it is plugged into the socket.
Thank you for your interest.
An easier option would be to use remote control plug in sockets which you plug into a normal socket then plug your appliance into,then switch on and off via the control
I did not know about the remote control switches and after googling I note they are available from Amazon.
Thanks for the tip.
Would replacing the socket with an FCU (with a large switch) feeding a new un-switched socket be a solution.
If you buy a single-to-double converter socket such as this you will end up with a switch on the left. You won't need to change the single back box for a double as it screws directly on as a replacement.
I've never seen a left handed single socket. Doesn't mean there isn't one!
Many thanks for your advice.
I will see how much slack cable there is behind the single gang socket and go for either the converta socket or the outboard switches (which involve a little more work fitting a back box but would be more compact).
Because the guys here are not being nosey for the sake of it, but want to know exactly what you are trying to achieve so that they could perhaps suggest a useful alternative, maybe one you had not thought of or did not realise existed.
In this case, such as the remote controlled adapters.
In the world of electrical installation, as other areas of life, there are often many ways to skin a cat.
