E27 usually refers to the standard size screw type bulbs, bayonets are refered to as B22 for the standard and B15 for the small size bayonets. Can you describe anything else about it, eg what it is for?
Hi can anyone help, i've just installed a 3 headed garden lamppost, i'm getting power to the post and to the bulb holder's but when i fit the bulb's no light. On the instruction's it does say "use E27 GLS type bulb's only and no other type", could'nt find this specific type so tried E27 ES.
Hi securespark, thanks for info on lightbulbs, they are screwed home sufficiently, yes power to the post live and neutral.I am using original wiring that was used to connect 2 outside light's,only difference is i've connected a waterproof junction box with the intention of using it for another light at a later date. I disconnected the cable from the junc box to the post and fitted a plug and connected to a extension lead just to prove the post worked ok it was fine.
Hi, thank's for all the advice, just a quick note to say i traced fault back to a cut in the original wire that had been repaired, i must of disturbed it when wiring to post, have now rewired from switch to JB, work's ok
