My hall light is not working. Basically it stopped working a while back when my friend incorrectly wired up the ceiling rose in the lounge. After he had done this, the hall light did not work, but a certain combination of the hall light and lounge light switches made both lights come on dimmed.
I did some research into this issue, discovered it was due to my lounge ceiling rose being incorrectly wired, and found out how to rewire it correctly. So I've now bought a multimeter, tested for the switched live, and I believe wired up the ceiling rose correctly. I put the switched live in the live terminal, the other switch wire in the loop, the other 2 lives in the loop and the other 2 neutrals in the neutral block. (6 wires total)
But my hall light is still not working. I've tried changing the bulb again, but I'm now out of ideas!
Can somebody please tell me if I've either incorrectly wired the ceiling rose, or if not what is my next step to identify the problem? If any steps involve using a multimeter, please explain as if I've never used one before (because as of last week I hadn't!)
Thanks in advance
Thanks in advance
