- Joined
- 29 Sep 2022
- Messages
- 95
- Reaction score
- 6
- Country
Am I right in thinking the red should be 2.5mm, while the blue can be 1mm? Thanks.
No.
All 1mm² is fine.
The MCB ( fuse ) protecting the sockets is probably a 32 Amp device. Taking a circuit fused at 32 Amp into a ceiling rose rated at 6 Amp is not a good idea.
Yes exactly, well done.Really? It's just that I've seen other stuff online that says everything up until the fuse should be 2.5mm. But I guess it does make sense that you can use 1mm for everything after the socket as that entire part is effectively limited to 3A.
Why are there regulations in place which allow you not to?I would say it's good practice to use the same size cable to feed the FCU then 1 milli on the load side.
It's a light.Is there still a 1.5 rule for "power" cables?
Again, why do you think it is allowed.The MCB ( fuse ) protecting the sockets is probably a 32 Amp device. Taking a circuit fused at 32 Amp into a ceiling rose rated at 6 Amp is not a good idea.
What about into a socket rated at 13 Amp?The MCB ( fuse ) protecting the sockets is probably a 32 Amp device. Taking a circuit fused at 32 Amp into a ceiling rose rated at 6 Amp is not a good idea.
When I install stuff, I try (you can't do it in every case) to make it future-proof.Why are there regulations in place which allow you not to?
But do the regs still disallow 1 milli to be used on "power" circuits?It's a light.
Why; what is going to happen?When I install stuff, I try (you can't do it in every case) to make it future-proof.
Did they ever?But do the regs still disallow 1 milli to be used on "power" circuits?
Think about faults.But... the current going through that 2.5mm will be limited by whatever fuse is in there, even though the fuse is 'after' that wire.
