LIGHT SWITCH QUERY
17 Aug 2003
Hello all,
Just wondering if I have need an earth on my light switch....
The outer case of the (dimmer) switch is plastic. The two screws are metal but actually screw into wood and not a metal plate casing, there was no earth wire connected - do I need to connect one?
I've been told no but I wanted to double check.
Thanks in advance!
Nick
In this instance you do not connect an earth wire, but there should be one there in case you change the switch to a metal one
HI
Thanks so much for that! I thought so, yes - there is an earth wire in there.
That's put my mind at rest!
Nick
