Is it controlled by a 2-gang switch with one gang for the luminaire and the other gang for the fan?
Are you saying that there is a second red (which I can't really see) coming from cable A, and that there are two reds (one from each cable, going into the top of connector 1 (again which I can't really see).
Do I take it that it was possible to switch on the fan even if the light was off?
If the new fitting is just a lamp then it will only have Live ( brown ) Neutral ( blue ) and Earth ( green/yellow)Yes. This flex goes directly into the fitting and it is 4 core. (1 -brown 2 -red 3 -black 4 -earth in the above photo)
So where does this 4 core come from....? Is it the cable from the old fitting. If it is then you can discard it.
The middle terminal is used to join the 2 reds.
The middle terminal is for the 2 reds which are already joined
A perfect example of why bas recomends learning how things work before tampering, this is basic electrics.
Thanks. Very useful. Wish I'd seen that earlier.
To be fair, I would imagine that everyone who was trying to help you (none of whom actually claimed to be an 'expert') assumed that we were dealing with at least a sort-of 'loop-in' wiring system (in the sense that the cable with two reds went to a switch, and the only one was the 'supply'). However, particularly given all the hidden conductors in your photos, that in itself was not enough to allow anyone to give you a definitive answer.20 odd posts in which none of the "experts" here quite figured out the problem ... and then I get to it by trial and error ... and then someone actually points me at the right answer .... and then you add you contribution which is to patronise me. ... How stupid of me not to have searched for "Traditional “loop-in” ceiling rose wiring, aka “3-plate”" before troubling you.
