Lighting circuit error
I have traced back the wires To where I started. The switch wire is ok, I was getting continuity readings from both. I thought this was expected but now and I clearly realise that this is a bad sign. I traced one of the wires back (I only just found this out) and it came to a shaving socket where the live wire was not in correctly, secured it and did the continuity test on it and it did not create a circuit. I am now going to trace the other wire.
I will add that this house was very poorly built and maintained. New internal walls built on top of carpet plastered walls over wallpaper etc!
