Previous occupants of our flat installed some strange ceiling lights, which required a larger than normal hole in the plaster on the ceiling for the wires. They took the fitting with them, leaving us with an ugly metal plate fixed across the hole and a bare bulb.
Ideally I'd simply have taken off the entire fitting just leaving the wires, bought a bog standard plastic ceiling pendant (like this one: http://www.screwfix.com/prods/15459...Sockets/White-Moulded/MK-Range/MK-Pendant-Set) and fixed it to the ceiling covering the hole.
However, the hole is too big and the is no way of fixing the pendant to the ceiling (the holes to attach it are too close to bridge the hole in the ceiling)
I cannot find, anywhere, plastic ceiling pendant larger than 85mm diameter. If I could find one that was 120mm or more, the problem would be solved.
Does anyone know of where I might find a large version of the bog standard plastic pendant light?
Thanks v much
Nick
Thanks v much
Nick
