Lighting Question
11 Nov 2007
Cambridgeshire
Just a quick query...
I'm replacing the lights in my kitchen, there are two lights (one at each end of the room), and they are operated by 2 switches, one by the back door, one by the living room (the lights are not independent of each other, they are either both on or both off).
I know how to replace a light, no problems. I just want to check that there is no reason that I will find anything untowards in the way of wiring compared to swapping a normal one light/one switch affair.
If so, what should I find!
Thanks in advance
Paul
You might, it depends on what mood the installer was in on the day that they installed it as to what wiring method was used.
shouldn`t pose a problem as long as you keep the wires the same they`ll either be switched via a junction box or via the ceiling rose`s
if it`s a junction box you`ll have less wires in the ceiling rose and it will be simpler
to check un-screw the ceiling rose and investigate take a picture :shock: or explain what you see either way as long as you keep all the wires the same you should be o.k.
Thanks chaps, I just wanted a rough idea before i got stuck in. If i get to it and i'm unsure i'll post a pic for further advice!
Thanks breezer, I always make a diagram now after the great light wiring debacle of 2001, but thats another story altogether! :D
