lighting with 4 wires including YELLOW????
7 Aug 2009
i have a lighting circuit with 4 wires, red, black, earth and also a yellow cable. these are controlled by 2 switches however the strip light only has the usual 3 terminals- HELP!!!!
I know its a long shot, but how was it wired before?
Take a photograph if you can, as even for us this may prove unusual.
And "the usual 3 temrinals"? Most light fittings have 4 terminals.
i'm new to the site- appoligies if i'm a bit slow on how to use website, hopefully we can all pass advise unlike idiots from russia called holmslaw
Will you be able to upload a picture of this cable?
I'm intreaged
Do you have any test equipment with you? Multimeter or the like?
He's not from Russia, his IP puts him in UK.
Holmslaw is not an idiot, but now and again he is a bit lippy. Just ignore the windups and wait for a sensible answer.
I'm intreaged
As i said, not sure if your receiving this, but will send photos when can- many thanks
I've had another message fron gavin the dip stick
"if u know what ur talking about then why the sarcastic reply in first place? the circuit contains live, neutral, earth + a yellow wire, the light only has live,neutral and earth terminals- if we can help each other then great, but your fist comment was not appreciated"
So once again, extremely interesting, but what is the question?
I do know what I'm talking about, but I genuinely don't know what you are talking about, its not my problem that you're a moron its yours.
i dont wish to fall out- four wires into a light that has 3 terminals, how does that work?? i thought i had made that clear, obviously not, appologies
Its not often I become enraged by a fellow helper on this forum, but Holmsaw, stop being such a pedantic idiot. The OP's problem is obvious, even if he didn't phrase it as a question. If you're not willing to help him, go away and stop cluttering up his thread.
Sounds like a two way switch circuit. Usually used to switch the landing light on/off from bottom of stairs etc. This wiring scheme can use 3 core + earth cable, eg black, red, yellow, and earth (should be sleeved green and yellow) I remember there being diagrams in the wiki section... but the diagrams aren't working for me. Try googling "two way light switching"
Good luck,
Mark
