1) Whereabouts in the country are you?i have a strip light fed by a single cable from light switch.
Wire your downlight cable into the strip light. There should be a triple terminal block inside the fitting. Connect to this terminal, copying the positions of the existing cable.
This will mean that the downlights will come on at the same time as the strip light.
Make sure that you use the correct size cable and that you are not exceeding the max. current of the circuit by adding 6 downlights (6 downlights = 300W = 1.3 A).
So in other words you didn't try what sparkyspike advised...i tried this but didnt work
i have cable running to choc block which serves other lights
If the strip light still works then you have got the new lights wired wrong
The last downlight should be wired into a junction box along with the 5th downlight. What sort of downlights are you fitting? On GU10 downlights, you can use the terminal block provided on top of the light fitting, but remember to connect the earth cable. On ELV downlights, you use junction boxes for the transformers or, if provided, use the terminals in the transformer itself.
The wiring from the 5th downlight connects into the same terminals as the 4th, and so on, until you're left with one cable - L N and E. Connect this directly into the L N and E terminals on the strip light. The L terminal should already have a red cable in it and the N terminals a black cable. These should remain in place when you wire in the new cables.
If you still have problems, then you're doing something fundamentally
wrong.
Erm yeah - take the cable out of the strip light and connect it to the new lights . . .
