Arcing can cause RCDs to trip - not sure how it happens but it does.
Poor Crafty - the AC supply in this country changes direction 100 times per second going positive 50 times and negative 50 times, up to 340v ish and down to -340v ish, the RMS value of which is 240v (using true readings).
It doesn't matter which way around you connect your probes on AC - the normal value which is read is the RMS.
Set your multimeter to volts AC ~.
Note the voltage may display negative, if you have your probes reversed.
