(I apologise in advance, far too long winded - the last two sentances are probably all you need to read but I know how you guys like your info!)
Just running through some caculations and I would be grateful if anyone could confirm my 'workings'. Obviously I will check with lintel company etc for finalising but I like to try and work things out for myself to get a better understanding.
I've been using the following for calculating the mass of an area
www.planningportal.gov.uk/uploads/br/BR_PDF_ADE_2003.pdf
Approved Document E, Annex A3.1 (table A.2 Page 73
My garage opening is 3.0m wide and blockwork is made up of 440x215x100 DCBs laid FLAT. My blocks weigh in at 18kg each. The overal length of this side of the wall is 4.8m and the gable wall will extend no higher than 2.5m above the lintel to an apex roof and will be of blocks laid on EDGE, single skin. For the purpose of this exercise i'm leaving out any affect of the roof on the lintel and wall surface finish. I have chosen a lintel length of 3.6m, a bit on the generous side perhaps.
So, from my method.
1) The triangle AREA of the gable wall above the lintel will be 9.0m2 [0.5 (3.6 * 2.5 ) * 2]
2) Mass of 1m2, with blocks laid on edge being 18kg, will be 190 Kg/m2 (table A.2)
3) Therefore mass of blocks above lintel will be 9x190=1710kg
So I think I have that bit sorted but where I am stuck is that when you look at any Lintel spec they give a unit of kN. Now I imagine the k is simply a 1,000 units so where the spec may say 20kN it in fact is 20,000N?
Also, then, is my result of 1710kg directly comparable to 20,000N??
Many thanks
c.
PS One thing I thought of, will I need a pier rising up to the apex?
So, from my method.
Many thanks
c.
