    Dismiss Notice
lintel installation
Discussion in 'Building' started by james2006, 3 Aug 2011.
  1. james2006
    james2006
    15 Mar 2006
    67
    Thanks Received:
    London
    Country:
    Hi - I am putting 2 new openings in my house through single supporting brick walls on the ground floor. The lintel lengths are 1200mm and 2100mm. Do I need padstones as each end or just lay them on the bricks.
    The reason I ask is I need to get all my materials on site before the builder arrives and also ensure construction is ok with BCO.
    Cheers
  2. Sponsored Links
  3. ^woody^
    ^woody^
    3 Sep 2006
    31,505
    Thanks Received:
    4,210
    West Mids
    Country:
    No padstones required for lintels. Normally.
  4. noseall
    noseall
    2 Feb 2006
    40,447
    Thanks Received:
    2,536
    Staffordshire
    Country:
    Agree with Woodchip.
    However, there can be varying bearing lengths depending upon the workload, i.e. 100mm, 150mm, 200mm etc.
  5. Richard C
    Richard C
    26 Apr 2005
    10,625
    Thanks Received:
    1,001
    Country:
    Isn't the the minimum end bearing 150mm :?:
  6. noseall
    noseall
    2 Feb 2006
    40,447
    Thanks Received:
    2,536
    Staffordshire
    Country:
    Not necessarily no, though 150mm has been adopted as a default setting.
    In a lot of small openings, (door size) lintels will happily sit on 100mm bearings.
  7. geraint
    geraint
    28 Aug 2008
    1,710
    Thanks Received:
    24
    Hampshire
    Country:
    everytime that the wall is 150mm wide.... :)
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
