Hi there, having a few issues with lintels, any help will be grateful.
i'm converting my lounge upvc windows into french doors, my house is a standard end terrace upstairs/downstairs affair. I have cavity walls with the internal leaf bearing the load of the floor rafts of upstairs and same again with the loft.
My nightmare is that i have no lintel on the external leaf of the wall, where a course of bricks have been laid horizontally across the entire window length (decorative) now that course of brick has a horizontal crack along the entire length of the window opening, this has now but pressure on the window frame which is now bowing
Also I have discovered a hairline crack running (vertically) through the middle of my internal lintel.
How do I go about squaring this problem away? Do I replace internal lintel first then the outside one? Can you get lintels that bridge both leafs of the walls, then its job done??
Any help would be much appreciated!
Cheers
Cheers
