Monsoon said:doitall said:monsoon,
You are not listening, the only body that can legally touch that pipe or the valve is the supplier and their agents. Transco/National Grid etc.
As such they are God.
Your only chance is to appeal against their better nature.
I am listening and I'll repeat what I said previously.
or anyone other than Transco.I have no intention of trying to turn it on myself
its a valve
It would have a handle for turning on/off but they removed that. Presumambly when the previous owners requested disconnection.with the handle removered
usually after a year it is cut off at the main
Dont really follow what you meanif inserted new it will catch on valve sockets ec
2 bar to 75 mbar is medium pressure you will have a service regulator on the service pipe if this is the case
possably be a dual service the were valved at the time of this pipe looking at photo
Since you've dragged me into this by means of a misquote, I'll exercise my right to present my opinion, and I would say that you've broken the law of common sense.Agile said:As Softus would say, which law have I broken?
...was very soon followed by some fast-footed, but ineffective, backpedalling, viz:Agile said:As I am CORGI registered I would turn it on...
Agile said:I have told you that if its a gas valve its Transco property and no one should tamper with someone elses property.
I never said that a CORGI registered person can turn it on.
It's too late.Monsoon said:Tony, I think u'd do yourself a favour by deleting your previous post.
Damian30 said:Hi,
There is a good chance that the service to your property has been disconnected under the requirements of the Gas Safety (Installation & Use) Regulations (Section 16(3)). Although this places duties on the Supplier, they are discharged by the Gas Transporter.
The live/dead test is carried out to ensure the service pipe across my property is live or dead, If that is the reason for the test? How can it be acceptable for the engineer to just test the capped off end within the property and pronounce the pipe dead when it's obvious there is a valve outside?It may be that the service was 'isolated' at the service isolation valve but generally for domestic properties this is done at the House Entry Tee (if it is an above ground internal entry on a PE service pipe) or physically at the main.
I dont get this - If the gas has been isolated the majority of the service pipe to my property will already have gas in it( the other side of the valve is only a few feet). Why should this now be deemed as inoperable? There's no indication it's leaking.It is likely that if the service has been isolated at the service vale, it will likely be inoperable or the service (particularly if steel) will not pass a test to recommission. In which case, you will need to pay for a new connection.
The pipe diameter is approx 2"Even if the service pipe can be re-commissioned, depending on your particular gas load and usage, it may not be suitable and you would need to request a capacity upgrade. This may or may not be chargeable depending upon your particular circumstances. You will also need to arrange with a Gas Supplier to have a meter fitted.
I don't think safety has been given top priority in my case as demonstrated by my example of the builders removing the 'dead' service pipe. If I was not of the mind to pursue this it is possible that we could have had an emergency situation on our hands.It is a case of 'buyer beware' when you purchase a property and the fact that there looks like what may be a gas service pipe to the property does not necessarily mean that it is connected to the gas distribution network. The fact that there may be a pipe to a property does not necessarily mean that the gas transporter has an obligation to use it (e.g. it may not be fir for purpose compared to current standards).
Clearly safety is the key driver in this complex area,
