Hi
I have put a building regs app in for doing our loft conversion and have had a list of questions back from the plan check. Most I have dealt with but any thoughts/advice on the following welcome as really can't see the sense in some of it.
Main issues are structural-
1. We have a load bearing masonry wall down the middle of the house which makes domestic floor joist spans relatively easy as spans less than 4m @400mm ctrs either way- the problem is there is an existing knock though on ground floor which Mr Inspector has asked for a calc.
I know there is a steel beam as we checked when moved into property . Is there a beam size table I can use or do I really need to get a struct eng to calculate and charge a day rate for a 5 min job . My gut feeling is its really not an issue as 1st floor is sound as a pound.
2. BC have asked for confirmation of lintels over 1st floor windows- Rather than mess about with putting new ones in and messing up plasterwork on 1st floor (as think they are just 90 year old timbers so not man enough), is it acceptable practice to double up the new floor joists either side of window and run a trimmer across ( window width vary 1.2-1.5m joists are 200x50mm).
3. There are some diagonal struts at mid purlin span which we will be taking out they don't appear to be doing much as they are flappy BC have asked to confirm support for the puriln (275x50mm spans about 5.1m). Are there any tried and tested means of doing this- vertical strut onto a doubled up joist?
4. BC have also asked that we insulate the party wall under part L- this doesn't make sense as doesn't this create a problem with interstitial condensation? and the party walls will be the best insulated walls in the house. On stair side it will run to first floor and eat up space on what is a fairly small house.
Cheers
J
Cheers
J
