Hi all,
Just had the loft decked out at the cost of £1000.
I moved into the house last year, the previous owner having done a refurb.
Part of this was a new roof.
Now that I can access the loft, I was shocked to find a slight leak at eaither end of the roof (mid terrace) where it meets the wall to the next property.
Even more worrying is that one of the short beams is now very rotten, having obviously beene exposed to this small leak for at least 1 year (probably more).
The brickwork at either side is not in a good state. The stuff nearest to the floor of the loft is fine, but as you get closer to the roof, the bricks are crumbling on touch. It seems to go about 1/2 inch into each brick, as once this crumbling is removed, the rest of the brick is solid to touch.
My first problem is to fix the leak (hopefully covered by home insurance), but replacing the small beam and then attending to the bricks is another matter.
I don't have lots of spare cash, so unless the insurance covers it, I will need to have a go myself.
Does the brickwork need to be totally replaced, or can it be patched up if I remove the crumbling and stop the leak?
Any advice more than welcome on what I should do, the approx cost if I paid to get it done, and how likely an insurance company would be to pay out.
