@JP_ one thing you will need to clarify is if you have gravity pressure hot and cold. Or, whether you have gravity hot and mains fed cold.
The latter may make your pump install a bit more complicated.
Also, you need to do some calculations based on the size of the cold water feed tank. If it is a tiny tank, you may find a pump feeding a bath or shower may drain it faster than it can re-fill.
That thread I posted earlier, I discuss all these issues, so it is worth a read.
