LOOSE ELECTRICAL FACEPLATE
8 Nov 2009
Hampshire
Hi
I have a twin socket that has a loose faceplate. The reason appears to be the metal retainer within the socket has become too large. I cannot easily replace the socket due to some poor tiling stopping me from replacing the whole unit.
Any ideas on how I can get rid of the loose faceplate?
If its the adjustbale lug, then canabalise one from a spare box
Just araldite a 3.5mm nut to the backface of the offending lug.
Do it up gently - should be ok
 8)
buy a 3.5 mm re-threader from a good electrical wholesaler.
get some pliers and give the lug on the box a bit of a twist so the screw hole becomes slightly distorted.
re-thread the hole with the re-threader. be careful with it as it can snap off in the hole.
use a new screw if the old one looks suspect.
Another option:
Drill out the existing metal lug with a 4mm bit, so the 3.5mm screw will pass through easily.
Drill a 3mm hole in the back of the metal box in line with the lug (use the lug as a guide), then thread the hole.
Fit the faceplate using a long screw which passes through the lug (to keep it in the correct place) and into the new threaded hole at the back.
Another option:
Go with this, great idea
thanks for all the responses. I actually went with the twisting of the lugs and then rethreading them. This appears to have done the job. so top jolly.
